Recommend for new bios update(UP^2)
apichat
apichat New Member Posts: 2 ✭
i would like to LED HDD blink. when read write EMMC or SATA port.(User LED on bord)
Has anyone agree with me?
  • WereCatf
    You can use the LEDs that are already on-board for that, if you use Linux: the LEDs can be found under /sys/class/leds. There's a virtual file called 'trigger', which controls what the LED should do, including blinking according to disk-access.
