IP-Cores and SDIO in UP2 Squared
I've reviewed UP2 Squared next category https://up-shop.org/4-up-boards#/up_board_version-up2_squared and I have several questions:
1. Will there be available IP-cores for the FPGA on the board?
2. On which devices from this series is SDIO exists as the most high-speed way to transfer data?
3. What will be the approximate price of the devices?
  • rogertsai(AAEON)
    Hi Greenwood
    I don't understand the question 2, you mean is which devices can support SDIO interface on UP2 board? or most high-speed interface on UP2 board?
  • John
    John New Member Posts: 4
    Hi, Roger. Yes, first case. Which devices (components) can support SDIO interface on UP2 board? Especially I need information about using SDIO with Altera Max 10.
  • rogertsai(AAEON)
    edited September 2017
    hi, Greenwood
    I have double checked it, and unfortunately, the UP2 Squared is not supported to use the SDIO interface
