Can you connect RPi parallel interface screens to the 40pin header?
I'm wondering if its possible to connect RaspberryPi display hats which use the gpio pins in parallel display interface mode (DPI)
As described here:
https://www.raspberrypi.org/documentation/hardware/raspberrypi/dpi/README.md
It would be great as I have this screen in mind (800x480 3.5inch):
https://shop.pimoroni.com/products/hyperpixel
It is an ideal size/resolution for my needs and supports proper capacitive touch, all via the gpio - cable free.
Cheers
Russell
