[SOLVED] Ubuntu16.04x64 kerner4 up 1080p display running out of screen
Shreesh Manasvi
New Member Posts: 5 ✭
Running : Linux me 4.4.0-2-upboard #12-Ubuntu SMP Thu Dec 1 15:01:52 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
(uname -a)
The 1080p screen resolution foes beyond screen (FHD Vise 39") tv display over HDMI.
I think this might be overscan issue as told by some. Please help me understand how to fix the same if possible. Thanks in advance.
(uname -a)
I never thought I could fix the screen by using TV settings. FOR THE RECORD I SWITCHED TO "POINT TO POINT" OPTION IN ASPECT RATION AND IT WORKED LIKE A CHARM.
Have you tried to change the display settings from the TV menu?
Some time you can switch from 16:9 to adapt/source, etc.
If not you can adjust via linux command line. -
Wow that was exact solution. I never thought I could fix the screen by using TV settings. FOR THE RECORD I SWITCHED TO "POINT TO POINT" OPTION IN ASPECT RATION AND IT WORKED LIKE A CHARM.
Thanks a lot . Now exploring the up board with ease . . .
