Up2 cluster? cases and form factor
Jan
Jan New Member Posts: 4 ✭
edited August 2017 in Chassis
Just found this board, and was thinking it could be used to set up a kubernetes mini-cluster?
but what is the form factor of these modules? it does not seem to comply to any standard?
could two of these be mounted to a back-plate of a mini-itx case perhaps?
I would like to se a stackable case with room for the board + 2,5" SSD, does such an option exist?
Jan
  • Aling
    Hi ,
    UP board has its proprietary form factor. There is no standard case to use.
    If you would like to make stackable design for your cluster system, you can do , but no standard chassis to use.
