Android not able to install
EricC
New Member Posts: 4 ✭
I just downloaded the Android image from the web site and followed the instruction in the installation guide, but the installation stopped after step 6 as in the guide and prompted "Android-x86 installer is not available. Press RETURN to run live version". I pressed RETURN and then it just showed "ANDROID" at the bottom of the screen with the cursor kept flashing. Nothing happened from here. Reboot a few times , still the same. Screenshot as attached.
Is there any problem with the Android image or what did I just do wrong ?
Eric
Eric
Sorry, the attached screen shot in last post seemed broken.
Anyway, I changed another USB disk ti build the Android image again ( Sandisk USB 3.0 32GB) and it's getting better. But there is still an issue when I click "No" in step 9 ( no use GPT ), the screen turned black and display "Warning !! Unsupported GPT (GUID Partition Table) detected. Use GNU Parted." at the bottom line. Click ENTER, then it shows "FATAL ERROR: Bad primary partition 0: Partition ends after end-of-disk. Press any key to exit cfdisk"
Any thought ? -
Were you able to figure this out. I have the exact same error.
Hi, did any of you figure this out because at the moment I am floundering my way through GPT to try and install it.
It seems it was solved by pcmg and reportend on the other topic: https://up-community.org/forum/general-discussion-up/2137-installing-marshmallow-on-an-up-board
I am closing this one as duplicate.
