Fail to install RealSense SR300 with UP Squared
NsonCC
Posts: 2 ✭
in Peripherals
I have been tested UP Squared with RealSense SR300.
I can install following driver on Windows 10, But I cannot install intel Depth Camera Manager driver due to missing "SR300 Virtual Driver"
Intel(R) RealSense(TM) Camera SR300 Depth (install succeed)
Intel(R) RealSense(TM) Camera SR300 RGB (install succeed)
Intel(R) RealSense(TM) Camera SR300 Virtual Driver(missing on Win 10)
Did anyone have same problem? Do you have any suggestion to solve this problem?
SR300 is working fine with my PC, but it fail to install RealSense SR300 with UP Squared
I believe UP Squared is powerful enough to drive RealSense SR300.
Testing detail as following:
Hardware:
Board: UP Squared Intel Pentium N4200 Quad Core up to 2.5 GHz, 8GB DDR4 64GB eMMC
Camera: Intel RealSense SR300 (BlasterX Senz3D )
Tested System:
Microsoft Windows 10 Creators 1703 64-Bit
Microsoft Windows 10 Anniversary Update 1607 64-Bit
Microsoft Windows 10 Threshold 2 Update 2 (Build 10586-164) 64-Bit
Tested Driver:
Intel RealSense Depth Camera Manager sr300_3.3.27.5718
Creative BlasterX Acoustic Engine Pro Software Pack for Windows
Hardware:
Tested System:
Tested Driver:
Got a chance to talk with RealSense team. They said RealSense camera is a software dependent device.
So you got to make sure the library/app/driver you are using is for the specific camera.
For more information, you may discuss at RealSense forum https://communities.intel.com/community/tech/realsense .
