i2c arbitration error...help!
Shawn Ransford
Shawn Ransford New Member Posts: 20 ✭
edited July 2017 in UP Board Linux
Hey all,
I am finishing a project for a client that utilizes i2c. I am using the mraa c++ library, but do not believe the library is at fault...I think it is the kernel i2c-dev code. After about 45 minutes of where I successfully write/read to my devices (5 sensors), I get this error in syslog...
kernel: [ 2941.297575] i2c_designware 808622C1:01: i2c_dw_handle_tx_abort: lost arbitration
I have tried rewriting the code in just about every way possible. Some Googling makes me think it is the kernel driver...and that is about the last "correction" I have left to attempt. I did get the latest mraa code and recompile in hopes it might help, but there were very little i2c changes since v1.0. I would share my code, but it is something higher level for sure. if I spin my wheels a little longer, I will write a simple routine to demonstrate. I am hoping someone else has run into this issue and has a fix.
My next thought is to compile the kernel driver... which has undergone some revisions. I assume I am not the first guy to use i2c on their up board for more than just a simple test. I need to continually request/read from these sensors without failure. All thoughts or help would be greatly appreciated!
Edit: Looks like this guy likely had the same problem...and never got a response...not good!
https://up-community.org/forum/public-upboardhw/1032-i2c-communication-stops-after-a-certain-time
  • Shawn Ransford
    I think I found a workaround! I disabled the option in the bios for PMIC ACPI. I have now been running without i2c failure all day :)
  • Shawn Ransford
    edited July 2017
    Well, It died again overnight. Lasted much longer, but I am still in need of a fix! Looks like it lasted a mere 8 hours after my last recompile. If it could at least go 24 hrs, then I could schedule a midnight reboot as a "fix" and patch later.
    Any chance Ubuntu is a better or at least more widely used choice?
  • Shawn Ransford
    edited July 2017
    Installed Ubuntu yesterday...same issue! Shouldn't surprise me though...same kernel, etc.
    Are you using long wires to connect your I2C device?
    Is it in an electrically noisy environment?
  • Shawn Ransford
    No wires...board is directly attached using pi header. Each of the devices are isolated as well.
    I just found a series of settings in the bios...that I swear were not there last time I looked. Would the bios have been updated at some point automatically? It has definitely changed. Regardless, I am adjusting those settings to see if they make a difference. First is i2c bus speed...went down to 100hz and I have now been running almost 10 hours...hadn't gotten that far before (the device can support up to 400hz, but worth a try). Any other bios settings of interest? Any other devices that could create a conflict on the kernel side?
    Thanks for the quick response! All thoughts are greatly appreciated.
  • Nicola Lunghi
    Nicola Lunghi New Member Posts: 4 ✭
    Can you send us a script to replicate the issue?
  • Shawn Ransford
    It looks like I might have a workaround. I changed the speed on the bus to 100hz...and it has been running for over a day :cheer:
