UP Board: issue adding touchscreen device support via ACPI overlay
wangyafei
wangyafei New Member Posts: 3 ✭
edited July 2017 in UP Board Linux
I want to add a touchscreen driver to ublinux. I want to add my touchscreen device under the i2c1 bus and do the following things:
1. Extract ACPI tables cat /sys/firmware/acpi/tables/DSDT > dsdt.dat
2. Decompile: iasl -d dsdt.dat
3. Add the following ASL code to dsdt.dsl
Device (I2C2)
            Name (_HID, "808622C1")  // _HID: Hardware ID
            Name (_CID, "808622C1")  // _CID: Compatible ID
            Device (TCS0)          /* add my touchscreen device here*/
                Name (_ADR, Zero)  // _ADR: Address
                Name (_HID, "GDIX1001")  // _HID: Hardware ID
                Name (_CID, "GDIX1001")  // _CID: Compatible ID
                Name (_S0W, Zero)  // _S0W: S0 Device Wake State
                Method (_PS3, 0, Serialized)  // _PS3: Power State 3
                Method (_PS0, 0, Serialized)  // _PS0: Power State 0
                Method (_CRS, 0, NotSerialized)  // _CRS: Current Resource Settings
                    Name (WBUF, ResourceTemplate ()
                        I2cSerialBus (0x0014, ControllerInitiated, 0x00061A80,
                            AddressingMode7Bit, "\\_SB.I2C2",
                            0x00, ResourceConsumer, ,
                        GpioInt (Edge, ActiveLow, Shared, PullDefault, 0x0000,
                            "\\_SB.GPO2", 0x00, ResourceConsumer, ,
                            {   // Pin list
                                0x0000
                        GpioIo (Shared, PullDefault, 0x0000, 0x0000, IoRestrictionOutputOnly,
                            {   // Pin list
                                0x0001
                    Return (WBUF) /* \_SB_.PCI0.I2C2.TCS0._CRS.WBUF */
                Method (_STA, 0, NotSerialized)  // _STA: Status
                    Return (0x0F)
                Method (INTI, 0, Serialized)
                Method (INTO, 1, Serialized)
                Method (INTS, 0, Serialized)
4. Recompile: iasl -tc dsdt.dsl
And now I have some questions about this,
1. Can I add my touchscreen device by the above steps?
2. If can, There have two gpio pins used by touchscreen device, one is irq-pin and another is reset-pin, they may described like following with ASL code:
GpioInt (Edge, ActiveLow, Shared, PullDefault, 0x0000,   "\\_SB.GPO2", 0x00, ResourceConsumer, , )
           0x0000
     GpioIo (Shared, PullDefault, 0x0000, 0x0000, IoRestrictionOutputOnly, "\\_SB.GPO2", 0x00, ResourceConsumer, ,  )
            0x0001
I want to use GPIO4 as irq-pin and GPIO5 as reset-pin in the "up-board 40-pin", can anyone tell me how to modify the above ASL code?
