Windows 10 compatibility
Thomas Hall
Thomas Hall New Member Posts: 32
Will the UPcore with 2GB RAM support full Windows 10 64-bit, or will I need to install 32-bit?
Many thanks,
Tom
    It will support Windows 10 64bit.
    It is important to consider that in order to install Windows 10 64bit you need 32GB eMMC or more.
  • Thomas Hall
    OK cool, thanks!
  • Patryk
    Patryk New Member Posts: 1
    Will UP Core support Windows sleep mode?
  • Andy Nicholson
    Andy Nicholson New Member Posts: 60
    edited June 2017
    ...although if you create your own image I'm pretty certain you could run it on the base model with 1GB RAM and 16GB storage, aaaand it depends on how you define "full Windows" :)
  • Peter Berbec
    Peter Berbec New Member Posts: 8
    There's always sweet, sweet swap!
  • Rudydevolder
    Rudydevolder New Member Posts: 2
    I am still confused about the Windows IOT, I found that it is OEM only and it has limited driver support.
    What it means?
    I can't download it and use the driver pack from this web site?
    I can see a full image download for the UP for Windows 10 iot but not for the UP CORE,
    So I can conclude Windows IOT isn't supported in the UP CORE?
