sata power plug seperatly?
Michael Miller
New Member Posts: 95 ✭
Hey, I have a combination SATA + 2 pin power plug connector that I bought in preparation for this, however the 2 pin power plug uses a JST style plug which the UP Squared does not use. Would it be possible to get just the power plug portion of this :
http://up-shop.org/up-peripherals/108-sata-cable-for-up-squared.html
Or possibly the part number for the plug? I have the ability to crimp a new connector if possible, but it would be easier to just splice it.
Hi ,
https://up-community.org/downloads/download/38-up2_assets/58-up-apl01_reva0_4_qig_20170407 this document may help you find a right connector for SATA power. -
Got some plugs online, incidentally a word of caution, how the plug pigtail manufacturer decides to wire the pin out and how UP does so is not always the same, also incidentally, i have discovered if you plug a SATA drive power in backward the UP will not boot, but there does not seem to be any damage done. SATA drive now working.
