Measuring battery voltage with ADC gpio
Thomas
Thomas New Member Posts: 18
edited May 2017 in UP Board Linux
I am trying to measure battery voltage using the ADC pin which is listed as gpio2 on the data sheet. However when I try to create the gpio object
mraa:Gpio adc = new mraa::Gpio(2);
I get the error "Invalid GPIO pin specified". Is the mraa gpio numbering the same as the datasheet's?
Also from what I read about the ADC, I think the command
printf("voltage %d \n",adc->read());
should print a integer between 0-255 which corresponds to the voltage between 0-3.3v on the gpio pin. Is this correct?
Thomas
