Connecting external power switch
Adam
New Member Posts: 11 ✭
in Peripherals
I've taken apart and a standard ATX power switch cable and successfully attached it to the 2 reset pins on the UPboard. The power pins in the white housing are too small and cramped to fit anything but the 2 bare wires.
I don't want to solder anything. What is the connection type for the power pins? Can anyone send me a link to power switch that can fit the UPboard without modification?
I don't have an UP-board, but from the pictures it looks like just a standard JST-PH 2.0mm header. You can buy JST-PH 2.0mm connectors on eBay or wherever and just make your own switch. Cramping the wires in the connector is a bit fiddly and there are professional tools for that, but I just use my pliers to do it myself.
So I could purchase these:
27Pcs Micro JST 2.0 2-Terminal Male Connector Wire Cables 12cm Length https://www.amazon.com/dp/B0167X4D9M/ref=cm_sw_r_cp_apa_F-pVyb83149ZZ
And splice them on a power switch cable. -
Aye, that should do it just fine.
Disregard the comment below - it's the wrong connector. Correct response here.
[strike]Let me add a few more links for other people searching the same, but wanting more information.
Manufacturer website of connector (JST PH series):
http://www.jst-mfg.com/product/detail_e.php?series=199
Part number is "PHR-2".
On the popular part supplier websites:
Connector itself:
http://nl.rs-online.com/web/p/pcb-connector-housings/8201466/
http://nl.farnell.com/jst-japan-solderless-terminals/phr-2/housing-2way-2mm/dp/3616186
Check also the related parts! There are cables available with the crimp connector already attached.
Complete cable:
http://nl.mouser.com/search/ProductDetail.aspx?R=0virtualkey0virtualkey1131
https://www.adafruit.com/product/1131[/strike] -
I appreciate the links. The connectors I ordered where too large.
Are you sure there extension cables are compatible. They also look too large.
Would these work?
Crazepony 3 Sets Tiny Whoop JST-PH 2.0 Pin Male Female Connector Cable Kit for Blade Inductrix Battery Upgrade https://www.amazon.com/dp/B01MSYXESK/ref=cm_sw_r_cp_apa_HNoXybHY0F59Y
Sorry, I'm just frustrated (my project is stopped due to the power pins).
Has anyone here made a power button extension?
I want to just take plyers and try to snap off the plastic housing around those pins but I know I'll probably destroy my UPboard. -
Just ordered this:
Adafruit JST-PH Battery Extension Cable - 500mm https://www.amazon.com/dp/B00DK2A2AI/ref=cm_sw_r_cp_apa_-bpXybT75AREE
In three days I might have a power button. -
The Adafruit JST-PH Battery Extension Cable that was suggested is still not the right part.
I notice the the CR2032 battery cable uses the needed cable connection. Where can I order one of those? It would be the solution. -
Now I ordered this:
New CMOS Battery 3V Lithium ML1220 RECHARGEABLE CMOS BATTERY With CABLE https://www.amazon.com/dp/B005J1UC30/ref=cm_sw_r_cp_apa_MvwYyb20B722C
Which I hope I can just cut of the cable portion and slice onto a switch button.
In another 3 days maybe I'll finally have a working power button.
It would be a fantastic idea to have a external power switch available in the up-shop peripheral section. -
I asked the makers of the S.USV UPs (https://shop.olmatic.de/en/home/12-susv-ups-4260434190081.html), as they use such a connector to connect their device to the power switch.
It turns out to be the Molex PicoBlade connector series.
http://www.molex.com/molex/products/family?key=picoblade
Exact part number used by Olmatic is 15134-0205.
You can find assemblies with different lengths of cable here:
http://nl.mouser.com/Wire-Cable/Cable-Assemblies/_/N-bkre6?P=1yzi0zu&Keyword=pico+blade&OrgTerm=picoblade&NewSearch=1&FS=True -
Thanks that looks exactly right.
I might receive a compatible cable tomorrow but if not I'll order the 15134-0205. -
So I finally did it...Sort of. The Rtc battery connect is correct. I spliced the cable on the end of a PC power button and it almost did what I want.
If I push the button the UPboard sleeps. If I hold down the button it powers down.
BUT, it won't turn on the UPboard. In fact the power button built in to the UPboard won't work with my power switch plugged in. I can unplug the AC adapter and plug it back in to turn it back on.
So I have a power off only button. I really just wanted power on functionality. Any suggestions? -
It actually can power on the UPboard I just need to hold down the power button for 2 seconds.
Issue resolved!!!
