Autounattend.xml - problem with partitions
Stefan
New Member Posts: 3 ✭
I'm trying to get an Autounattend.xml file working to install Windows 10 Insider from USB.
But the installation stops with
The installation was canceled
Windows could not set a partition active on disk 0. The target disk, partition, or volume does not support the specified operation. The error occurred whilte applying the unattend answer fils' <DiskConfiguration> setting. Error code: 0x80300024
Here is the Autounattend.xml I put onto the USB stick after copying all Windows 10 files from ISO to USB.
Would be great if we find out what blocks the unattend installation. I tried several different settings, types, and partitions with similar errors.
<?xml version="1.0" encoding="utf-8"?> <unattend xmlns="urn:schemas-microsoft-com:unattend"> <servicing/> <settings pass="windowsPE"> <component xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS"> <DiskConfiguration> <!-- http://www.msfn.org/board/topic/154404-how-to-clean-gpt-hard-disk-using-autounattendxml/ --> <WillShowUI>Always</WillShowUI> <Disk> <DiskID>0</DiskID> <WillWipeDisk>true</WillWipeDisk> <CreatePartitions> <CreatePartition> <!-- Create the Recovery partition --> <Order>1</Order> <Type>Primary</Type> <Size>450</Size> </CreatePartition> <CreatePartition> <!-- Create the EFI partition --> <Order>2</Order> <Type>EFI</Type> <Size>100</Size> </CreatePartition> <CreatePartition> <!-- Create the MSR partition --> <Order>3</Order> <Type>MSR</Type> <Size>128</Size> </CreatePartition> <CreatePartition> <!-- Create the Windows partition and fill the rest of the hard disk --> <Order>4</Order> <Type>Primary</Type> <Extend>true</Extend> </CreatePartition> </CreatePartitions> <ModifyPartitions> <ModifyPartition> <!-- Modify the recovery partition --> <Order>1</Order> <PartitionID>1</PartitionID> <Format>NTFS</Format> <Label>Recovery</Label> <TypeID>de94bba4-06d1-4d40-a16a-bfd50179d6ac</TypeID> </ModifyPartition> <ModifyPartition> <!-- Modify the system partition --> <Order>2</Order> <PartitionID>2</PartitionID> <Active>true</Active> <Format>FAT32</Format> <Label>System</Label> </ModifyPartition> <!-- The MSR partition does not need to be modified --> <ModifyPartition> <!-- Modify the Windows partition --> <Order>3</Order> <PartitionID>4</PartitionID> <Format>NTFS</Format> <Label>Windows</Label> </ModifyPartition> </ModifyPartitions> </Disk> </DiskConfiguration> <UserData> <AcceptEula>true</AcceptEula> <FullName>User</FullName> <Organization>User</Organization> <!-- product key --> <!-- <ProductKey><Key>xxx</Key> <WillShowUI>Never</WillShowUI> </ProductKey> --> </UserData> <ImageInstall> <OSImage> <InstallTo> <DiskID>0</DiskID> <PartitionID>4</PartitionID> </InstallTo> <WillShowUI>Always</WillShowUI> <InstallToAvailablePartition>false</InstallToAvailablePartition> <InstallFrom> <MetaData wcm:action="add"> <Key>/IMAGE/NAME</Key> <Value>Windows 10 Enterprise VL Insider Preview</Value> </MetaData> </InstallFrom> </OSImage> </ImageInstall> </component> <component xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS"> <SetupUILanguage> <UILanguage>en-US</UILanguage> </SetupUILanguage> <InputLocale>en-US</InputLocale> <SystemLocale>en-US</SystemLocale> <UILanguage>en-US</UILanguage> <UILanguageFallback>en-US</UILanguageFallback> <UserLocale>en-US</UserLocale> </component> </settings> <settings pass="offlineServicing"> <component name="Microsoft-Windows-LUA-Settings" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS"> <EnableLUA>false</EnableLUA> </component> </settings> <settings pass="oobeSystem"> <component xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS"> <UserAccounts> <AdministratorPassword> <Value>Passw0rd!</Value> <PlainText>true</PlainText> </AdministratorPassword> <LocalAccounts> <LocalAccount wcm:action="add"> <Password> <Value>Passw0rd!</Value> <PlainText>true</PlainText> </Password> <Description>Cloud User</Description> <DisplayName>demouser</DisplayName> <Group>administrators</Group> <Name>demouser</Name> </LocalAccount> </LocalAccounts> </UserAccounts> <OOBE> <HideEULAPage>true</HideEULAPage> <HideWirelessSetupInOOBE>true</HideWirelessSetupInOOBE> <NetworkLocation>Home</NetworkLocation> <ProtectYourPC>1</ProtectYourPC> </OOBE> <AutoLogon> <Password> <Value>Passw0rd!</Value> <PlainText>true</PlainText> </Password> <Username>demouser</Username> <Enabled>true</Enabled> </AutoLogon> <FirstLogonCommands> <SynchronousCommand wcm:action="add"> <CommandLine>cmd.exe /c powershell -Command "Set-ExecutionPolicy -ExecutionPolicy RemoteSigned -Force"</CommandLine> <Description>Set Execution Policy 64 Bit</Description> <Order>1</Order> <RequiresUserInput>true</RequiresUserInput> </SynchronousCommand> <SynchronousCommand wcm:action="add"> <CommandLine>C:\Windows\SysWOW64\cmd.exe /c powershell -Command "Set-ExecutionPolicy -ExecutionPolicy RemoteSigned -Force"</CommandLine> <Description>Set Execution Policy 32 Bit</Description> <Order>2</Order> <RequiresUserInput>true</RequiresUserInput> </SynchronousCommand> <SynchronousCommand wcm:action="add"> <CommandLine>cmd.exe /c reg add "HKLM\System\CurrentControlSet\Control\Network\NewNetworkWindowOff"</CommandLine> <Description>Network prompt</Description> <Order>3</Order> <RequiresUserInput>true</RequiresUserInput> </SynchronousCommand> <SynchronousCommand wcm:action="add"> <CommandLine>%SystemRoot%\System32\reg.exe ADD HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\ /v HideFileExt /t REG_DWORD /d 0 /f</CommandLine> <Order>6</Order> <Description>Show file extensions in Explorer</Description> </SynchronousCommand> <SynchronousCommand wcm:action="add"> <CommandLine>%SystemRoot%\System32\reg.exe ADD HKCU\Console /v QuickEdit /t REG_DWORD /d 1 /f</CommandLine> <Order>7</Order> <Description>Enable QuickEdit mode</Description> </SynchronousCommand> <SynchronousCommand wcm:action="add"> <CommandLine>%SystemRoot%\System32\reg.exe ADD HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\ /v Start_ShowRun /t REG_DWORD /d 1 /f</CommandLine> <Order>8</Order> <Description>Show Run command in Start Menu</Description> </SynchronousCommand> <SynchronousCommand wcm:action="add"> <CommandLine>%SystemRoot%\System32\reg.exe ADD HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\ /v StartMenuAdminTools /t REG_DWORD /d 1 /f</CommandLine> <Order>9</Order> <Description>Show Administrative Tools in Start Menu</Description> </SynchronousCommand> <SynchronousCommand wcm:action="add"> <CommandLine>%SystemRoot%\System32\reg.exe ADD HKLM\SYSTEM\CurrentControlSet\Control\Power\ /v HibernateFileSizePercent /t REG_DWORD /d 0 /f</CommandLine> <Order>10</Order> <Description>Zero Hibernation File</Description> </SynchronousCommand> <SynchronousCommand wcm:action="add"> <CommandLine>%SystemRoot%\System32\reg.exe ADD HKLM\SYSTEM\CurrentControlSet\Control\Power\ /v HibernateEnabled /t REG_DWORD /d 0 /f</CommandLine> <Order>11</Order> <Description>Disable Hibernation Mode</Description> </SynchronousCommand> <SynchronousCommand wcm:action="add"> <CommandLine>cmd.exe /c wmic useraccount where "name='demouser'" set PasswordExpires=FALSE</CommandLine> <Order>12</Order> <Description>Disable password expiration for user demouser</Description> </SynchronousCommand> </FirstLogonCommands> <ShowWindowsLive>false</ShowWindowsLive> </component> </settings> <settings pass="specialize"> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS"> <OEMInformation> <HelpCustomized>false</HelpCustomized> </OEMInformation> <!-- Rename computer here. --> <ComputerName>blue</ComputerName> <TimeZone>GMT Standard Time</TimeZone> <RegisteredOwner/> </component> <component xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" name="Microsoft-Windows-Security-SPP-UX" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS"> <SkipAutoActivation>true</SkipAutoActivation> </component> </settings> <cpi:offlineImage xmlns:cpi="urn:schemas-microsoft-com:cpi" cpi:source="catalog:d:/sources/install_windows 7 ENTERPRISE.clg"/> </unattend>
Hi Scherer
We had the same problems with a unattended file for Windows Server 2016.
This was are solution for the problem.
Don't know if it works for Windows 10 but you can give it a try.<?xml version="1.0" encoding="utf-8"?> <unattend xmlns="urn:schemas-microsoft-com:unattend"> <settings pass="windowsPE"> <component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DiskConfiguration> <Disk wcm:action="add"> <DiskID>0</DiskID> <WillWipeDisk>true</WillWipeDisk> <CreatePartitions> <CreatePartition wcm:action="add"> <Order>1</Order> <Type>EFI</Type> <Size>400</Size> </CreatePartition> <CreatePartition wcm:action="add"> <Order>2</Order> <Extend>true</Extend> <Type>Primary</Type> </CreatePartition> </CreatePartitions> </Disk> <WillShowUI>OnError</WillShowUI> </DiskConfiguration> <ImageInstall> <OSImage> <InstallTo> <DiskID>0</DiskID> <PartitionID>2</PartitionID> </InstallTo> </OSImage> </ImageInstall> </component> </settings> <cpi:offlineImage cpi:source="wim:c:/" xmlns:cpi="urn:schemas-microsoft-com:cpi" /> </unattend>
Thank you FreekingNL.
I'll give it a try. And at least it gives me the evidence that it should work in some way.
Windows 2016 would be better for me, too.
I have tried splitting the install.wim into 4GB parts and then run the installation, but after a reboot it doesn't find its boot device. I have seen another forum tip to extract the drivers and put it into the install.wim. But as I am installating from the big ISO with both desktop and core, these files are already inside the wim file, I think.
