Up-board with RandA
Carlo
Carlo New Member Posts: 1 ✭
Hi, it's possibile to use the Up-boards with RandA?
  • Dan O'Donovan
    Hi CarloMiele
    I don't see any obvious reason why it wouldn't work. It looks like it uses only the UART TX/RX pins and 2 GPIOs to communicate with the Arduino. The RTC could be used over I2C as well, but would be redundant on the UP Board because it already has a built-in RTC.
    Best regards,
    -Dan
