Heatsink with fan
Jimmy Mot
New Member Posts: 13 ✭
in Peripherals
hi
again a question
i also purchased a heatsing with fan instead of the passive one
how do i attach it ??
where do the power cables go??
how do i remove the passive one
any tutorials??
again a question
any tutorials??
There is a "Active heat sink exchange SOP"-PDF under Download: http://up-shop.org/up-peripherals/64-active-cooler-fan-for-the-up-board.html
great thanks
in my case the battery is a bit in the way
and this heatsink is quite good attached
it does not come lose easy
i am scared of damaging the battery or the device -
Link in above posting is dead:
UP active heat sink exchange SOP
And yes, it comes off not very easily. You might try to pull on a cooling fin with a small pair of tongs. Of course do it gentle. -
Do you mean this link:
"UP active heat sink exchange SOP"
http://up-shop.org/index.php?controller=attachment&id_attachment=11
It works for me. It should take you to a PDF download
