MIPI-CSI cameras for UpBoard
Riccardo Lardi
Riccardo Lardi New Member Posts: 8 ✭
As far as I have read there are NO cameras available that work on the MIPI-CSI connector of the UpBoard, is this still true? I'm looking to connect an IR-Cam to blob track people for a media installation. Would it be an option to use an IR-Cam over USB then? If so, which would you recommend?
Thanks for any help!
  • Fabrizio
    Fabrizio Guest Posts: 123 ✭
    Hi Alberto,
    yes, CSI cameras are not yet available.
    We are working with Intel and Chicony on a CSI camera.
    We suggest to use a normal USB camera.
    We don't have any preferred one.
    If you need a 3D camera we suggest the Intel R200 that has been tested and certified by Intel to run on UP board using the USB 3.0 OTG port.
    Cheers
  • Riccardo Lardi
    Hi Fab, thanks, just to ask, is it a pinout issue that no MIPI-CSI cameras for example the Rasperry Pi ones can be used? Could it be a solution to make an adapter for these to fit the UpBoard? It would be great if the Raspberry Pi cameras could be used on the UpBoard, too.
  • Fabrizio
    Hi Alberto,
    as we have explained few months ago to the community, it's not possible to connect any CSI camera because a fine tuning is needed and only Intel and the camera maker together can do it.
    BR
