Dan O'DonovanAdministrator, Moderator, EmutexPosts: 241admin
Hi. Sorry for the late reply to this. It is possible to control these LEDs if you are using one of our supported Linux kernels (e.g. ubilinux or Ubuntu, available in the Downloads section).
The addon with key CloudflareImageResize could not be found and will not be started.
#0 [internal function]: Vanilla\Logging\ErrorLogger::handleError(1024, 'The addon with ...', '/var/www/fronte...', 1121)
#1 /var/www/frontend-4ea011bb3e5da3/library/Vanilla/AddonManager.php(1121): trigger_error('The addon with ...', 1024)
#2 /var/www/frontend-4ea011bb3e5da3/bootstrap.php(542): Vanilla\AddonManager->startAddonsByKey(Array, 'addon')
#3 [internal function]: {closure}(Object(Vanilla\Utility\TracedContainer), Object(Vanilla\AddonManager), Object(Gdn_Request))
#4 /var/www/frontend-4ea011bb3e5da3/vendor/vanilla/garden-container/src/Container.php(353): call_user_func_array(Object(Closure), Array)
#5 /var/www/frontend-4ea011bb3e5da3/bootstrap.php(481): Garden\Container\Container->call(Object(Closure))
#6 /var/www/frontend-4ea011bb3e5da3/index.php(28): require_once('/var/www/fronte...')
#7 {main}
