PWM and Serial on 8/10
1. How can i write a PWM signal to a PWM pin using the cSharp SDK/API
2. How can I setup serial communication of pins 8/10 (gpio14/15).
3. Can someone explain what the bitmask is for, and how we utilise it?
I had assumed once the drivers were installed the 8/10 combo would show up as a com port as it does in IoT but till so far no luck.
(there IS a com1 available from boot even without drivers, but I cannot find what it is or how to access it)
Thank you in advance
as so but replacing RPi with the UP.
About your questions:
-> Windows doesn't support to control PWM signal.
-> Pin 8 and Pin 10 is unavailable under Windows.
-> Bitmask is like a "filter", please refer to related SDK API parameter to use. (No need to set the value ourselves)
Please use CN17 Tx Rx TTL signal.
Does this work in linux using the rpi.gpio softPWM command? If -YES- then its worth looking at writing a routine to do that in windows I guess, depending on if the pins can be accessed fast enough for it to make sense?
OK. Will look this up, cant seem to find any info at hand on doing it, but I'm being lazy I'll dig deeper.
OK. Noted. I figured it might be related to the PWM question above, if its not relevant i wont mess with it.
About question 1, PWM SDK development relates to project plan.
As I know currently UP-CHT01 doesn't plan to develop Windows PWM API/SDK .
Sorry I can do nothing about project planning..
I suggest you can mail to "customiza[email protected]", give them your feedback and they will know user requirement and evaluate this.
Thanks.
