How to enable spidev0.0
Thomas Mueller
Thomas Mueller New Member Posts: 3 ✭
I'm on
Linux ubilinux 4.4.0-ubi3-amd64 #1 SMP Debian 4.4.13-1 (2016-06-17) x86_64 GNU/Linux
Problem is I cannot get spidev0.0 to work. Seems that the module was loaded on boot, but I cannot see it in "/dev/".
Is there any trick I can do?
By the way... Spidev2.0 is available from boot.
Thx and greetings.
  • Dan O'Donovan
    On UP, you need to use /dev/spidev2.0. It will give you access to the SPI pins on the HAT header. It is equivalent to /dev/spidev0.0 on Raspberry Pi.
  • Thomas Mueller
    OK, sorry for my stupid question.
    Sometimes I should just try things instead of asking such questions ;-)
    It's working great with using spidev2.0.
    Thanks for your answer!
