extra 2 usb2 ports
Andrew Hays
New Member Posts: 45 ✭✭
where do i plug the 3 pin extra bit that hangs off the extra 2 usb ports that came in the kit.
i'm assuming its pins 2(+5v),4(+5v),6(common)
2 x UP board, 4GB RAM + 64 GB eMMC w/ vesa case
1x UP Squared Pentium Quad Core, 8GB RAM, 128GB eMMC w/ vesa case
1x UP Core Plus E3950, 8GB RAM, 64GB EMMC+ Net Plus i210-IT
1x Dell Power Edge R510
2x Dell Power Edge R610
I think I've found my answer.
https://up-community.org/wiki/Serial_console#Using_the_provided_adapter
the 3 pin plug is the terminal connection??2 x UP board, 4GB RAM + 64 GB eMMC w/ vesa case
2x Dell Power Edge R610 -
Yes that is the debug uart, you can use to install ubilinux via serial and also to access the bios menu
thanks...
i haven't looked at ubilinux yet.. i wanted to see how well the full server distro of ubuntu ran first. i might try widows 10 next. then maybe a thin client, to compare that to my Rpi3.2 x UP board, 4GB RAM + 64 GB eMMC w/ vesa case
