How to enable the GPIO 8, 10 as standard Serial port TXD and RXD in Ubu 14.04?
He Zhang
New Member Posts: 6 ✭
Hi all:
Currently I have been stuck in sending data through the serial port /dev/ttyS0, that is the GPIO pin number 8, 10. I made a serial cable as shown in the figures, on one side an external hoarder connects to the GPIO 6, 8, 10, GPIO 6 connects to ground, and on the other side it connects to a standard serial interface. I wrote a simple serial communication program that send data from the up-board to the desktop.
The problem is, I can successfully send data through a USB-to-Serial cable but failed through this serial cable. I have checked that this serial cable has been made correctly, so I am doubting whether there are some configures that I do not make to enable the GPIO 8,10 functions as a Serial port. I have tried some suggestions posted on https://up-community.org/wiki/Serial_console, but still not solve my problem. I also check the configures in the BIOS, end enable all the serial ports, but still not working.
Any help will be greatly appreciated!
IMHO if i understand your schematic you are going to fry your board.
PC DB9 serial connector uses RS232 levels while the GPIO is 3V TTL.
You need a level shifter... -
Hi Thanks for replying,
Again I checked the upboard documentation, that the pin number 6 is ground, 8 is GPIO14-UART0_TXD , and 10 is GPIO15-UART0_RXD, that are connected to the pin number 5, 2 and 3 on the PC DB9 serial connector. There is no GPION that is used as output to the PC DB9 serial connector. -
The docs mention to use an FTDI cable therefore the serial port is clearly TTL levels.
Thanks for your help, I made a mistake.
Best,
- 70 Product News - New Product/Product Change Notice/ End-of-life
- 3.5K UP Products
- 24 UP 7000
- 15 UP Squared Pro 7000
- 24 UP Xtreme i11
- 141 UP Xtreme
- 223 UP Core
