Best method to connect an extra SATA SSD disk
Thomas van Onzen
Thomas van Onzen New Member Posts: 2
What is the best method to connect an extra SATA SSD disk?
It seems to me that an USB3 to SATA connector is the best solution, but am I missing any options?
    No you are not ;)
    If you are going to connect an SSD I strongly suggest you use a USB3 to SATA bridge.
    Also please note that the UP board comes with a USB3 OTG port (micro USB3).
  • Thomas van Onzen
    Hi again,
    is the csb502ssd a good option now? i
  • Marcello
    dcleri wrote:
    No you are not ;)
    So now USB3 works for storage? New bios?
    My post was from 4 months ago, more recent tests from us and the community highlighted the instability issues with USB3.0 and storage devices (more when using the uas driver).
    For now the ssd shield, also available in the UP shop, is the best option.
    http://up-shop.org/home/54-502ssd-msata-solid-state-drive-shield.html
  • Marcello
    Sorry on mobile the forum does not show the date!
    you are right, thanks for the feedback!
  • William Henning
    William Henning New Member Posts: 17
    Interesting board!
    Would it not limit the SSD to a fraction of USB2.0 speed?
    I'd love to see some benchmarks.
  • Gary Blake
    Gary Blake New Member Posts: 18
    I've bench marked my SSD over USB3.
    Benchmark results
    Its running of a hub mind with lots of other things attached!
  • Marcello
    Benchmark results
    Hi there, what ssd are you using and how is it connected?
    Do you experience any errors?
  • Gary Blake
    OCZ and a old SSD from 5 years ago.
    No problems at all. I think we got trolls on the forum as this SBC is superb. I use one in my garage/workshop linked with 100M of ethernet to do my backups off site so to speak.
  • Marcello
    Trolls..? Actually the issues with USB3 are confirmed by UP and even by intel...
    Are you sure yours is usb3, to start with..?
  • Dan O'Donovan
    Not sure if its been mentioned yet, but we've noticed that using the following cable can make a BIG difference to the stability of USB3.0 connections:
    http://up-shop.org/up-peripherals/56-usb30-microb-to-microb-cable.html
    If you're seeing stability issues with USB3.0 harddisks or sata adapters, I suggest giving that cable a try if you can.
  • Gary Blake
    edited October 2016
    I have an OTG USB 3.0 and have attached a plugable USB 3.0 docking station to give me 2 USB 3.0 and 2 USB 2.0 ports, gigabit ethernet, 2 more displays and audio in out.
    Works a charm and has been working for 2 months now without a hitch! Even added a blutooth 4 device so i can play music from android devices through my up board.
    I have a USB 3.0 2TB HDD attached for backups (cwRsync for windows) and user storage + apps.
    Wrote this on my Up board win 10 from my workshop.
  • Marcello
    Well, you mentioned trolls in the forum but you don't do much to add to your own credibility. Docking station? which one? 2 more displays? Really? Which USB3 storage are you using? Oh, I thought you mentioned you were using an SSD last time but it is now an HDD.
    Can you substantiate your claims in any way?
  • Gary Blake
    No I bench marked the SSD for the guy that wanted to see some to be helpful.
    I described my day to day usage in my last post that is all.
    I said the make very clearly. Its a Plugable USB 3.0 docking station.
  • Gary Blake
    Link to the product used: http://plugable.com/products/ud-3900/
    Hard disk is a seagate slimline that has a 2TB Samsung hard disk inside it.
  • Jared O'Dell
    Jared O'Dell New Member Posts: 3
    I've had good success with a pi drive (http://wdlabs.wd.com/products/wd-pidrive-314gb/) connected with a short USB 3 Micro B to USB A OTG adapter and a short USB A to USB 3 Micro B cable. Oddly enough, the pi drive never actually worked well with the raspberry pi. It has been working flawlessly with the Up Board though.
