help my up no boot ( hs? )
gat
gat New Member Posts: 20 ✭
HELP ME HELLO my card will not boot more screens to nothing in short I n ais not touch the bios and I am using a charger 5v 3a
my card is broken ?
sorry i m french i m little speak
I 've let the light with windows without activating the day since two weeks without soussi and tonight she no longer mache you have a solution?
  • Aling
    edited September 2016
    Hi gat,
    Before you do any OS installation, let's verify if the board is good or not.
    Follow the quick-start-guide Step by step :
    1. Connect HDMI cable
    2. Connect power cable
    If you can see UP boot up logo, then the board is good. What you need to do is to follow OS installation guide.
    You will find it here. https://up-community.org/wiki/Setup
    If you are not sure whether you have messed up the BIOS setting earlier, unplug the BIOS battery for a few minute then plug it back. Again follow the quick-start guide .
  • gat
    hello what you propose does not work to me I have already try
      map heats the charger is connect
  • Pierre
    Pierre New Member Posts: 1 ✭
    Help,
    I've the same problem. The power led is blue but nothing at screen. No logo , no bios .. nothing.
    Why?
