UP Squared i12 Edge Series - Reboots When Trying to Install Ubuntu
Hello! I just purchased an UP Squared i12 Edge Series box, which says it supports Ubuntu 22.04 LTS (and offers an option to have 24.04 Ubuntu (Pro License) installed for an additional surcharge). However, I've tried a wide range of Ubuntu versions from 20 to 24, and it always reboots after I try to "install or try" Ubuntu. I've tried changing the grub boot flags, and that's sometimes made some difference in how far along in the process it gets, but it inevitably reboots before loading any graphics.
I feel like I had to use a specific installer, or change a setting, to get Ubuntu installed on my old board. But ,if so, I can't recall what I did. So... any assistance/advice would be greatly appreciated! I'm also open to Debian or Ubuntu Desktop, or whatever... but I don't want to just keep shooting blind, if i can help it.
  • HarryChiu
    HarryChiu New Member Posts: 235 ✭✭✭
    Hi @lifesaglitch
    We've never encountered this problem before. What are your power supply voltage and current (A)??
    Harry Chiu
  • lifesaglitch
    lifesaglitch New Member Posts: 4 ✭
    edited October 2025
    Thank you for the reply! I did not realize it had higher power requirements than my previous Up board, so right now I'm using an adjustable adapter set at 12 V. I don't know its amperage, and I'm unable to check for a few days. If you think that could be a factor, I can prioritize buying an adapter from Up. I also purchased a new flash drive which will arrive over the weekend, so I'll to see if that makes any difference as well.
    So there shouldn't be any special version of Ubuntu I need to use or BIOS/UEFI settings I need to adjust, to your knowledge? It should just work?
  • lifesaglitch
    You actually might be onto something. I was able to find the specs for my power adapter. It's capability is 3-12 V @ 0-2 A. The specs for the computer suggest typical consumption is 30-36 W.
    12 V @ 2 A means a max of 24 W. I'll get a new adapter and try it as soon as I am able (early-mid next week).
  • HarryChiu
    edited November 2025
    Dear @lifesaglitch
    A higher power supply is required; please refer to our datasheet.
    We recommend using a 12V / 10A power supply.
    No need to modify BIOS settings.
    Harry Chiu
