EAPI_STATUS_ERROR when starting Hi-Safe
I install fresh copy of Windows 10 IoT Enterprise 64Bit on fresh UP4000.
I have updated the BIOS to GPIO configuration.
I have installed all windows updates and UP drivers from the driver pack.
I receive error EAPI_STATUS_ERROR when starting Hi-Safe v3.
Version number is: 3.11.2.26
After error is closed, when Hi-Safe window appears, no options are able to be selected
Thank you.
  • karlhm761
    karlhm761 Posts: 6
    The error went away, it was because I was using 32bit EAPI on a 64-bit system. I will perform some more testing though to make sure the pins are operational.
