Touchscreen driver problem
clevesque
clevesque New Member Posts: 11 ✭
edited August 2016 in Peripherals
we used an Eleduino7" LCD with touchscreen and it was working correctly with the raspberry pi. We try to also use it with the UP board. The LCD is working correctly with the UP board but the touchscreen doesn't seems to work. When checking with lsmod, the same generic "hid_multitouch" driver seems to be loaded like in raspbian. Any idea on how to make it work on ubilinux?
