installation of WIN10_64 - Step_1 drivers fails
Henk Ringersma
Henk Ringersma New Member Posts: 15
edited July 2016 in UP Board Windows
When installing the WIN10_64 - Step_1 driver as an Administrator (or not), the process fails with error:
"The requested operation failed, A system reboot is required to roll back changes made"
The log file I have attached.
Please help
last part of log file ----
09:17:51:480: Reading config file : C:\drivers WIN10_64\WIN10_64\Step_1-Chipset_and_peripherals\WIN10_64\Config.xml
09:17:51:572: Read SocPackageInfo Version : 0x1
09:17:51:587: Reading string value
09:17:51:619: Read XML SocPackageInfo Root : HKEY_LOCAL_MACHINE, Key : SOFTWARE\Intel\SOCPackageInfo, Value : VersionNumber, Version string name : Version, version string : 102
09:17:51:634: Registry key SOFTWARE\Intel\SOCPackageInfo does not exist or can not be read. Error : Unable to read registry value : VersionNumber - Error Code : 2. Assuming the installed version is oldest. Proceeding with installation.
09:17:51:656: Preparing UI
09:17:51:687: Reading config file : C:\drivers WIN10_64\WIN10_64\Step_1-Chipset_and_peripherals\WIN10_64\Config.xml
09:17:51:703: Read Title Override : Intel x64 CherryTrail-T Driver Package
09:17:51:734: Reading config file : C:\drivers WIN10_64\WIN10_64\Step_1-Chipset_and_peripherals\WIN10_64\Config.xml
09:17:51:756: Read Title Override : Intel x64 CherryTrail-T Driver Package
09:17:51:787: Showing dialog: WELCOME
09:19:32:695: Showing dialog: LICENSE
09:20:08:878: Showing dialog: CONFIRM
09:20:37:757: Started installation thread
09:20:37:778: Setup mode
09:20:37:794: Showing dialog: PROGRESS
09:20:38:010: Read registry subkey Code and value 2
09:20:38:041: Read registry subkey Reboot and value 0
09:20:38:063: E Unable to pre-install driver file : C:\drivers WIN10_64\WIN10_64\Step_1-Chipset_and_peripherals\WIN10_64\Drivers\MBI\MBI.inf - error code : 2
09:20:38:079: E Uninstalling drivers that were previously pre-installed by DriverPackagePreInstall...
09:20:38:094: E Setup aborted!
09:20:38:125: m_nCurrentIndex : 4
09:20:38:178: Showing dialog: FINISH
  • Jacky Kuo
    Jacky Kuo New Member Posts: 70
    Looks "WIN10_64 - Step_1 driver" folder name causes this problem.
    Please move entire "WIN10_64" folder to Desktop then try to install driver.
  • Jacky Kuo
    Looks "drivers WIN10_64" or "Step_1-Chipset_and_peripherals" folder name causes this problem.
  • Henk Ringersma
    edited July 2016
    Thanks. That helped!
    I guess no spaces are allowed in the folder names for Step_1 drivers.
  • Fabio
    Fabio New Member Posts: 22
    Hello to all
    I have the same problem
    I have tried it as in the photo but the problem remains.
    Can you help me, please?
    Thank you
  • rogertsai(AAEON)
    In most cases, installing the Intel® CherryTrail-T driver goes smoothly and turns out to be a success.
    In your case, please follow the steps below to check for your UP board
    1. Back to bios, and restore defaults
    2. The driver package re-download again
    >> To UP-Board
    >> To UP-Squared
    3. reinstall the driver package again
    And what is your BIOS version?
  • Fabio
    edited September 2017
    Hello
    For up2 kikstarted , should I use To UP-Board or To UP-Squared?
    I have a up2 and install To UP-Board .
    I use Up-APL01 R1.8 UPA1AM18 0f 06/23/2017
    The last bios is ?
    This is log file
    2017:09:17 18:41:50:621:
    2017:09:17 18:41:50:637: >>> Log start
    2017:09:17 18:41:50:637: Mutex with given name doesn't exist. Creating new one.
    2017:09:17 18:41:50:653: Obtained mutex succesfully.
    2017:09:17 18:41:50:653: Single-instance mutex has been obtained
    2017:09:17 18:41:50:653: Core version: 2.5.48
    2017:09:17 18:41:50:668: Setup version: 2.0.29.0
    2017:09:17 18:41:50:668: Command line: "D:\20160307\Step2-TXE\SetupTXE.exe"
    2017:09:17 18:41:50:684: OS data: 6-2-1-0 64-bit
    2017:09:17 18:41:50:699: System up time: 200 sec
    2017:09:17 18:41:50:699: Reboot pending: No
    2017:09:17 18:41:50:715: Current UI language: 0410
    2017:09:17 18:41:50:731: Language folder: C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp
    2017:09:17 18:41:50:793: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\ar-SA\IntelCommon.dll. Lang 0401. Rank 0
    2017:09:17 18:41:50:871: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\cs-CZ\IntelCommon.dll. Lang 0405. Rank 0
    2017:09:17 18:41:50:934: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\da-DK\IntelCommon.dll. Lang 0406. Rank 0
    2017:09:17 18:41:50:981: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\de-DE\IntelCommon.dll. Lang 0407. Rank 0
    2017:09:17 18:41:51:043: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\el-GR\IntelCommon.dll. Lang 0408. Rank 0
    2017:09:17 18:41:51:106: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 1
    2017:09:17 18:41:51:168: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\es-ES\IntelCommon.dll. Lang 0C0A. Rank 0
    2017:09:17 18:41:51:231: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\fi-FI\IntelCommon.dll. Lang 040B. Rank 0
    2017:09:17 18:41:51:293: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\fr-FR\IntelCommon.dll. Lang 040C. Rank 0
    2017:09:17 18:41:51:356: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\he-IL\IntelCommon.dll. Lang 040D. Rank 0
    2017:09:17 18:41:51:403: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\hu-HU\IntelCommon.dll. Lang 040E. Rank 0
    2017:09:17 18:41:51:465: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\it-IT\IntelCommon.dll. Lang 0410. Rank 3
    2017:09:17 18:41:51:528: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\ja-JP\IntelCommon.dll. Lang 0411. Rank 0
    2017:09:17 18:41:51:575: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\ko-KR\IntelCommon.dll. Lang 0412. Rank 0
    2017:09:17 18:41:51:637: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\nb-NO\IntelCommon.dll. Lang 0414. Rank 0
    2017:09:17 18:41:51:684: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\nl-NL\IntelCommon.dll. Lang 0413. Rank 0
    2017:09:17 18:41:51:746: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\pl-PL\IntelCommon.dll. Lang 0415. Rank 0
    2017:09:17 18:41:51:809: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\pt-BR\IntelCommon.dll. Lang 0416. Rank 0
    2017:09:17 18:41:51:871: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\pt-PT\IntelCommon.dll. Lang 0816. Rank 0
    2017:09:17 18:41:51:934: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\ru-RU\IntelCommon.dll. Lang 0419. Rank 0
    2017:09:17 18:41:51:996: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\sk-SK\IntelCommon.dll. Lang 041B. Rank 0
    2017:09:17 18:41:52:059: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\sl-SI\IntelCommon.dll. Lang 0424. Rank 0
    2017:09:17 18:41:52:121: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\sv-SE\IntelCommon.dll. Lang 041D. Rank 0
    2017:09:17 18:41:52:184: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\th-TH\IntelCommon.dll. Lang 041E. Rank 0
    2017:09:17 18:41:52:246: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\tr-TR\IntelCommon.dll. Lang 041F. Rank 0
    2017:09:17 18:41:52:309: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\zh-CN\IntelCommon.dll. Lang 0804. Rank 0
    2017:09:17 18:41:52:356: Found C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp\zh-TW\IntelCommon.dll. Lang 0404. Rank 0
    2017:09:17 18:41:52:387: Loading language 0410
    2017:09:17 18:41:52:403: Setup mode: Installation
    2017:09:17 18:41:52:418: Looking for OS: 6.1.1 6.2
    2017:09:17 18:41:52:434: OS check passed
    2017:09:17 18:41:52:450: .NET not required, skipping requirement check
    2017:09:17 18:41:52:450: Resolving driver source
    2017:09:17 18:41:52:465: Using embedded driver(s). Temp source is 'C:\Users\SERVER~1\AppData\Local\Temp\IIF1714.tmp'
    2017:09:17 18:41:52:606: Using folder 'C:\Users\SERVER~1\AppData\Local\Temp\IIF1714.tmp' as the driver source
    2017:09:17 18:41:52:622: Scanning all active devices
    2017:09:17 18:41:52:637: Scanning x64\TXEI.inf (Name: TXEI64, Version: 2.0.0.1067)
    2017:09:17 18:41:52:653: Section with the best match: Intel.NTamd64.6.1
    2017:09:17 18:41:52:668: Device: PCI\VEN_8086&DEV_2298 (Intel(R) Trusted Execution Engine Interface )
    2017:09:17 18:41:52:684: MUP OS bits: 0xB6C00
    2017:09:17 18:41:52:684: Scanning x86\TXEI.inf (Name: TXEI32, Version: 2.0.0.1067)
    2017:09:17 18:41:52:700: No section match
    2017:09:17 18:41:52:715: MUP OS bits: 0x49200
    2017:09:17 18:41:52:731: E Win32 exception occurred!!
    2017:09:17 18:41:52:731: Error code: 0x4E24 (20004)
    2017:09:17 18:41:52:747: Error text: ''
    2017:09:17 18:41:52:762: Extended error text: 'Error in device matching'
    2017:09:17 18:41:52:778: Debug info: 'Setup.cpp (257)'
    2017:09:17 18:41:52:778: Reading storyboard
    2017:09:17 18:41:52:793: Page count: 7
    2017:09:17 18:41:52:809: Added: Welcome
    2017:09:17 18:41:52:825: Added: Modify
    2017:09:17 18:41:52:825: Added: License
    2017:09:17 18:41:52:840: Added: Confirm
    2017:09:17 18:41:52:856: Added: Progress
    2017:09:17 18:41:52:856: Added: Finish
    2017:09:17 18:41:52:872: Added: Error
    2017:09:17 18:41:52:887: Reading string map
    2017:09:17 18:41:52:903: No string map present
    2017:09:17 18:41:52:981: Showing page: Error
    2017:09:17 18:41:58:256: Link: Launching 'C:\Users\SERVERmicro\Intel\Logs'
    2017:09:17 18:42:04:444: Dumping properties (25 total)
    2017:09:17 18:42:04:460: IIF_MSILOGLEVEL=4096
    2017:09:17 18:42:04:475: INSTALL_TXEI=1
    2017:09:17 18:42:04:491: INSTALL_DAL=1
    2017:09:17 18:42:04:506: INSTALL_TCS=1
    2017:09:17 18:42:04:522: INSTALL_SPE=1
    2017:09:17 18:42:04:538: IIF_LOGFOLDER=C:\Users\SERVERmicro\Intel\Logs
    2017:09:17 18:42:04:538: IIF_SETUPVERSION=2.0.29.0
    2017:09:17 18:42:04:553: IIF_PACKAGEVERSION=2.0.0.1067
    2017:09:17 18:42:04:569: IIF_SETUPPATH=D:\20160307\Step2-TXE
    2017:09:17 18:42:04:585: IIF_CACHELOC=C:\ProgramData\Intel\Package Cache\{176E2755-0A17-42C6-88E2-192AB2131278}
    2017:09:17 18:42:04:600: IIF_OS=10.0
    2017:09:17 18:42:04:616: IIF_DEBUG_REPORTEDVERSION=6.2
    2017:09:17 18:42:04:632: IIF_OSSERVICEPACK=0
    2017:09:17 18:42:04:632: IIF_IS64=1
    2017:09:17 18:42:04:647: IIF_NET40CLIENT=1
    2017:09:17 18:42:04:663: IIF_NET40FULL=1
    2017:09:17 18:42:04:678: IIF_NET45CLIENT=1
    2017:09:17 18:42:04:694: IIF_NET45FULL=1
    2017:09:17 18:42:04:710: IIF_INSTALLFOLDER=C:\Program Files\Intel\TXE Components
    2017:09:17 18:42:04:710: IIF_LANGCOUNTRY=it-IT
    2017:09:17 18:42:04:725: IIF_RESOURCEFOLDER=C:\Users\SERVER~1\AppData\Local\Temp\IIF104D.tmp
    2017:09:17 18:42:04:741: IIF_SETUPMODE=INSTALL
    2017:09:17 18:42:04:757: IIF_EXITCODE=1602
    2017:09:17 18:42:04:772: IIF_LICENSE=
    2017:09:17 18:42:04:772: IIF_README=
    2017:09:17 18:42:04:788: Dumping feature states
    2017:09:17 18:42:04:803: Feature: 'DriverFeature' | Package: '{B75FA462-A375-4F12-AF79-ACB6D79E60F2}' | Current: 'false' | New: 'false'
    2017:09:17 18:42:04:819: Feature: 'DALFeature' | Package: '{BBCD444B-4502-4301-A21B-FE61006E72B4}' | Current: 'false' | New: 'false'
    2017:09:17 18:42:04:835: Feature: '' | Package: '{BBCD444B-4502-4301-A21B-FE61006E72B4}' | Current: 'false' | New: 'false'
    2017:09:17 18:42:04:835: Feature: 'TCSFeature' | Package: '{BBCD444B-4502-4301-A21B-FE61006E72B4}' | Current: 'false' | New: 'false'
    2017:09:17 18:42:04:850: Feature: 'ALL' | Package: '{DAB2D6B9-54CE-4225-B2C6-0535AEEF18A9}' | Current: 'false' | New: 'false'
    2017:09:17 18:42:04:866: Exit code (command line): 1602
    2017:09:17 18:42:04:882: >>> Log End
  • rogertsai(AAEON)
    UP2 = UP-Squared, so you should use UP-Squared drive on your UP2 board
    click here to download the UP2-windows 10 driver
    and the last version is UPA1AM21, please click the link below for UP2 BIOS
    UP2-uefi-BIOS
  • Fabio
    Ok thanks @roger1tsai
    but I have two new problems >
    1) There are no bios files on your page
    2)Installing all Windows 10 drivers and updating does not yet recognize 5 peripherals: audio, pci, and 3 unknown peripherals
  • David Rolfe
    David Rolfe New Member Posts: 98
    roger1tsai wrote:
    .....and the last version is UPA1AM21, please click the link below for UP2 BIOS
    UP2-uefi-BIOS
    Unfortunately the file (and instructions) appear to have 'vanished' for the moment!
    Hopefully they will quickly be restored!
  • Fabio
    Hello @Montala
    OK thanks for your confirmation.
    Do you know how to fix my missing driver problem?
    Thank you
  • David Rolfe
    Hi ninoo,
    Not immediately, I'm afraid, but hopefully once the BIOS files are available again, which I am sure they will be fairly quickly, and you have been able to update the BIOS on your board, then the procedures outlined above in posts from roger1tsai will be of some help to you.
