Errors with PWM usage on Up4000 Windows IoT Core
I am trying to use PWM on the Up 4000. I have created my Windows IoT Core image following your instructions here, and it successfully boots and GPIO works fine. I'm also running with the Up Framework.
I have downloaded your sample, however this does not seem to run. The code:
controller = await PwmController.GetDefaultAsync();
Fails to run with error:
"Could not set desired frequency."
I have configured the pin in the BIOS for PWM. What am I missing please?
Thanks.
