Serial Communication via UART
I’m trying to boot a Type 1 Hypervisor on the Upboard v2 Edge and am trying to use the serial console to read data (eventually going to a headless setup); I have attempted to utilize the RS-232 COM port that is broken out on the board, but I am not getting any usable information, nor the ability to input anything on the serial connection. The datasheet mentions that there is a UART0 and UART1; which (if either) is used to connect to the serial console? Furthermore, what is connected to the RS-232 COM port that is broken out on the case?
  • HarryChiu
    HarryChiu New Member, AAEON Posts: 235 mod
    Hi Sir
    Could you please provide me more information??
    Which OS do you use, Windows 10 or Linux??
    Version is??
    Harry Chiu
  • Carter
    Carter New Member Posts: 6 ✭
    edited September 2023
    Hello Harry,
    We are operating on Ubuntu 20.04; it looks like the external COM port is connected to UART2, but I'm not sure how to output this UART to a screen terminal session using PuTTy.
    Carter
  • Carter
    At this point, we are able to view the GRUB boot menu and the BIOS using the broken out UART0 on the 10-pin wafer; however, it is not possible to view serial output on UART0 after booting Ubuntu, which prevents us from utilizing the board for our purpose. Any ideas?
  • HarryChiu
    Hi Sir
    Could you please provide the version of bios??
    Harry Chiu
  • Carter
    USEHAM10
  • HarryChiu
    Hi Sir
    I reproduced your problem with minicom and solved it.
    Please modify the setting of bios.
    advance > HSUART > Windows UART Sub Device Report
    Set to disable, and try again.
    Harry Chiu
  • Carter
    Hi Harry,
    This seems to work in the short term, I was able to get output on my terminal window and interface with the board remotely. For future reference, does this support I/O port serial devices, or just MMIO?
  • HarryChiu
    Hi Sir
    To modify the settings of bios "Windows UART Sub Device Report" is depends on your OS.
    Enable this option is for windows.
    Linux does not have devices manager like windows.
    It will be an unknown device in Linux and occupy ttyS4.
    Harry Chiu
  • Carter
    I suppose I may have worded my question poorly; I was asking if there was any way to configure the serial ports to utilize the legacy configuration (0x3F8, etc.), rather than the mmio ports that it currently has.
  • HarryChiu
    Hi Sir
    You can use it after disabling "Windows UART Sub Device Report"
    Harry Chiu
