How To Do BIOS_chip_flashing on upsquared pro 7000 ?
DRAM_tester
DRAM_tester New Member Posts: 1 ✭
edited August 2023 in UP Squared Pro 7000 BIOS
Hello, all
how can BIOS flashing be done in hardware on the upsquared pro 7000 ?
For upsquared there is a description here
https://github.com/up-board/up-community/wiki/BIOS_chip_flashing
is there a similar method for the upsquared pro 7000 ?
The BIOS image I would take from
https://www.aaeon.com/en/p/up-board-up-squared-pro-7000#downloads.
I do have a dediprog SPI programmer.
I make changes to the BIOS advanced settings CBR, for memory stress tests, so there is a risk I will brick the board.
Thanks a lot
JG
Ooops, Might have found answer already
https://github.com/up-board/up-community/wiki/BIOS_chip_flashing_on_UP_Squared
then just a small difference in connector CN22 on upsquared pro vs. CN18 on upsquared pro 7000
