UP Squared USB power configuration
BGolias
BGolias New Member Posts: 1 ✭
I am wondering if the USB ports on the UP Squared Pro can be powered off when the board is powered down through the BIOS or not. Thanks!
Best Answer
  • Wilbert
    Answer ✓
    Hi Sir,
    By BIOS power off, do you mean shutdown?
    If so, it cannot be done with the current hardware, and it needs to be changed by adjusting the hardware.
    There will be this design in consideration of the usage of most users.
    Wilbert Lee
