UEFI screen times out really quickly!
From Windows 10 restart to UEFI screen, the UEFI screen times out so fast that I cannot review the settings, much less make any changes. What's Up?
  • Wilbert
    Wilbert Posts: 168 ✭✭✭
    Hi Sir,
    I can't understand your question very clearly.
    Now the boot process is too fast, causing you to be unable to adjust?
    Or when entering Build in UEFI and making relevant adjustments, the scrolling is too fast and you can't see the above message?
    Or something else? Can you have pictures or videos to explain?
    I hope I understand your problem clearly so I can offer suggestions/methods to solve your problem.
    Wilbert Lee
  • AmazingMrX
    AmazingMrX Posts: 1
    @Wilbert said:
    Hi Sir,
    Precisely that.
    When you boot into UEFI, after a short period, it continues loading into the OS anyway.
    So there's currently no way to configure UEFI settings with an OS installed.
    At least that was my experience on 4 of these boards with Ubuntu installed.
  • Wilbert
    edited June 2023
    Hi Sir,
    You can try to enter the BIOS to disable quiet boot, or press F7 when booting to select the fast boot.
    If you want to change the Ubuntu kernel, I remember pressing F4 during the boot process to enter the GRUB menu and let you make some choices.
    Hope the above information can solve your problem.
    Wilbert Lee
