HDMI Audio: no hw mixer
fga
fga New Member Posts: 3
We are able to use HDMI with audio using kernel driver snd_hdmi_lpe_audio, but it looks like the audio card does not define any controls, so it is not possible to have multiple
sources streaming towards HDMI/audio concurrently.
Has anyone had the same problem ? Is there a way to solve this ?.
Br,
Best Answer
  • garyw
    Answer ✓
    @fga
    UP-BOARD has no HW audio codec on the board, maybe you can try to use USB audio device for workaround.
  • Wilbert
    Hi Sir,
    Please make sure your connected device supports HDMI Audio.
    I assisted in testing a lot of things here, and confirmed that if the connected screen does not have a speaker, there will be no Audio device under Linux, including the way of using an adapter.
    If there is a monitor that supports speakers, or an adapter that supports Audio, there will be an Audio device available for use.
    Wilbert Lee
  • fga
    Let me rephrase a bit the problem:
    • Streaming the audio through HDMI works (obviously using a screen with speakers), but we cannot concurrently stream audio to the HDMI (something required with most webrtc apps).
    • Defining an Alsa dmix PCM does not help either, since without hardware support the up-board does not cope with the heavy computing required by software-only mixing solutions.
  • fga
    Thanks @garyw . It looks however as a dead-end for us, since we need to use a wireless HDMI dongle to stream video and audio to a remote screen.
  • Wilbert
    Hi Sir,
    You can try to refer to the following URL, there are adjustments for HDMI, can it solve your problem?
    https://github.com/up-board/up-community/wiki/Ubuntu_18.04
