UP Xtreme Edge Compute Wifi Kit Install
Hello -
I just received my UP Xtreme Edge Compute and purchased the Wifi kit. I have looked on the forum and wiki for installation instructions but have not found anything. Are there instructions or at least some pictures for the installation?
Thanks.
  • FredyHsu
    FredyHsu Administrator, Moderator, AAEON Posts: 55 admin
    Hi Jam68,
    do you purchase the Intel 9260 Wifi Kit? I will provide the SOP for you soon.
    UP Team
    Fredy
  • Janphr
    Janphr New Member Posts: 3 ✭
    Any update on this?
    I try to get the AC 9260 running on UPX-WHLI7C1-A20-16064, but the connection is slow and very unstable.
    Doing sudo apt-get install backport-iwlwifi-dkms results in:
    Setting up backport-iwlwifi-dkms (8324-0ubuntu3~20.04.5) ...
    Loading new backport-iwlwifi-8324 DKMS files...
    Building for 5.4.0-1-generic
    Building initial module for 5.4.0-1-generic
    Error!  The /var/lib/dkms/backport-iwlwifi/8324/5.4.0-1-generic/x86_64/dkms.conf for module backport-iwlwifi includes a BUILD_EXCLUSIVE directive which
    does not match this kernel/arch.  This indicates that it should not be built.
    Skipped.
    so I got it directly from git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
    sudo cp -v -u iwlwifi* /lib/firmware
    sudo update-initramfs -uk all
    but no improvement...
    Any advice?
