100 Pin Connector Cable?
Where can i buy the 100 Pin connector cables for Expansion A and B? I only need access to two GPIO pins and four USB 3.0. Seems to be the only way, because none of the available carrier boards fit my requirements. Before anybody asks, i don't want to use a USB-Hub. Thanks in advance!
Hi Sir,
We do not sell related cables.
If you want USB expansion, you may need to design the expansion version yourself.
In the early stage of development and testing, it is still recommended to use USB HUB.Best Regard.
Hello Wilbert,
thank you for your answer. Unfortunately, that's what I thought. The problem is, what is the name of this type of connector? Otherwise it will be difficult... -
Hi sir,
I understand your question.
The connector we used is Panasonic.AXK6S00647YG and has a height of 5.3mm.
The height of the female connector needs to be selected according to the user's needs.Best Regards,
Wilbert Lee -
Hello Mr. Lee,
thank you for the quick response! This piece of information is exactly what i needed!
Have a good day,
S. Muller
