GPIO not working with RT patch
I'm trying to use GPIO pins on up2.
My kernel is
Linux up 5.4.65-rt38+ #1 SMP PREEMPT_RT Mon Feb 28 13:42:31 CET 2022 x86_64 x86_64 x86_64 GNU/Linux
I compiled this up linux repository with the RT patch for the right kernel version and the following options:
SYSTEM_REVOCATION_KEYS: no SYSTEM_TRUSTED_KEYS: no HZ_PERIODIC: yes NO_HZ_IDLE: no CONFIG_NTP_PPS: no HIGH_RES_TIMERS: yes CONFIG_HZ_1000: yes CONFIG_HZ: 1000 CONFIG_OF: no CONFIG_AUFS_FS: no CONFIG_PREEMPT_RT: yes PREEMPT: yes PREEMPT_RT_FULL: yes PREEMPT_COUNT: yes PREEMPTION: yes DEBUG_PREEMPT: yes CPU_IDLE: no INTEL_IDLE: no CPU_FREQ_DEFAULT_GOV_PERFORMANCE: yes
Then I installed the upboard-extras
package
# Install extras sudo add-apt-repository ppa:aaeon-cm/5.4-upboard sudo apt update sudo apt install upboard-extras # Add groups for group in gpio leds spi i2c; do if ! getent group $group >/dev/null; then addgroup --system $group fi done # Add User sudo usermod -a -G gpio ${USER} sudo usermod -a -G leds ${USER} sudo usermod -a -G spi ${USER} sudo usermod -a -G i2c ${USER} sudo usermod -a -G dialout ${USER} sudo reboot
I am able to communicate with a chip using spi so I think the permissions are right.
I tried the following code without success
echo 432 > /sys/class/gpio/export echo out > /sys/class/gpio/gpio432/direction echo 1 > /sys/class/gpio/gpio432/value
I measure with a multimeter on pin 432 (pin 13 from this wiki and I get 0.1V.
Am I missing something?
PS: I cannot see anything when ls /sys/class/leds/
, why?
Best Answer
My problem was that I was compiling the kernel with a generic ubuntu configuration and not the up-board configuration.
I instealled Ubuntu 20 again, then used the procedure in the wiki to patch the kernel with the up-board kernel. Then I copied back the config at
/boot/
and used it to compile the kernel again with RT.After that, I installed again Ubuntu 20 on the Up squared and installed the debian packages of my previously compiled RT-upboard-patched kernel and now it works. I can control the GPIO and the leds.
I am trying now the kernel proposed by the wiki.
up@up:~$ uname -a Linux up 5.4.0-1-generic #0~upboard5-Ubuntu SMP Fri Jan 7 11:53:57 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Now I can see the leds and control the GPIO pins.
Am I compiling the right kernel or should I use another repository?
Doing a diff on
lsmod
for both kernels I got this:# Modules lodaded on generic but not in realtime snd_sof_intel_hda 20480 1 snd_sof_intel_hda_common leds_upboard 16384 0 pinctrl_upboard 16384 0 ulpi 20480 1 dwc3 upboard_fpga 20480 0 # Modules loaded on realtime but not in generic snd_soc_hdac_hda 20480 1 snd_sof_intel_hda_common pinctrl_broxton 40960 0
So basically the kernel with the realtime patch is not loading
pinctrl_upboard
andleds_upboard
so I think this is why I cannot control the GPIOs.When trying to load them manually:
up@up:~$ modprobe -v pinctrl_upboard modprobe: FATAL: Module pinctrl_upboard not found in directory /lib/modules/5.4.65-rt38+ up@up:~$ modprobe -v leds_upboard modprobe: FATAL: Module leds_upboard not found in directory /lib/modules/5.4.65-rt38+
Any way I could have those modules on a realtime patched kernel?
When I do a diff on the output of
lsmod
from both kernels I get this# Modules lodaded on generic but not in realtime snd_sof_intel_hda 20480 1 snd_sof_intel_hda_common leds_upboard 16384 0 pinctrl_upboard 16384 0 ulpi 20480 1 dwc3 upboard_fpga 20480 0 # Modules loaded on realtime but not in generic snd_soc_hdac_hda 20480 1 snd_sof_intel_hda_common pinctrl_broxton 40960 0
Apparently the
pinctrl_upboard
and theleds_upboard
are not being loaded so I think this is why I cannot control the GIPOs on my up squared.If I try to load them I get the following error
Also, on the realtime kernel I can find the .ko files for leds and pinctrl at
up@up:/lib/modules/5.4.0-1-generic$ find . | grep -i leds-upboard ./kernel/drivers/leds/leds-upboard.ko up@up:/lib/modules/5.4.0-1-generic$ find . | grep -i pinctrl-upboard ./kernel/drivers/pinctrl/pinctrl-upboard.ko
with no chances on
Any way I can have an Ubuntu with realtime patched kernel and working GPIOs on Up squared?
