UP Squared Pro Voltage
The datasheet quotes a power requirement of "12~ 24V DC-IN". I looked in the manual for more information, and there is a jumper labeled 12V and another labeled 24V. Do I need to set the 24V jumper to safely give the board 24V? What is the minimum and maximum voltage in 24V mode if so? How could I give it an intermediate voltage, like 16V?
  • New Member Posts: 1
    I do have the same questions .. Did you get any answers outside the forum ?
    Vincent
  • New Member Posts: 2
    edited March 2022
    I emailed the company directly and this is the response I got:
    For power DC input, it is not necessary to set the jumper for UP Squared pro. That DC input 12-24v is auto detected to work.
    The manual shows two jumpers labeled "PWR Select 12V (CN31)" and "PWR Select 24V (CN32)". It’s used for eDP PWR Select 12V & eDP PWR Select 24V, not used for UPS pro power input.
    I plugged 24V into my board while leaving the jumper on 12V and it worked fine, so it seems they are right and 24V is safe without any adjustments.
Welcome!
