UP Xtreme i11 Won't Turn Up
I've used UP Xtreme i11 for some time and then it suddenly stopped working.
It won't power up anymore.
Is there a known problem with it?
Is there a way to diagnose it?
Regards,
Tal
Hi @tallu,
Have you checked to see if the Power Supply unit is okay? Kindly give more context.
Hi @camillus
The power supply hasn't changed. Everything worked and suddenly stopped working. -
Hi @tallu,
Does the Ethernet LED come on? If you are sure the Power Supply unit is still okay then one thing to try is to unplug the RTC for a minute or two and reinsert, then try to Power ON again. If it does not come ON then please proceed with RMA if you bought directly from UP shop or raise the RMA via your distributor if you bought from them.
Hi @camillus,
The Ethernet LED comes on. What does that mean? -
Hi @camillus,
Forgot to mention. I've removed the battery for a few minutes and then connected it back.
Still, the system won't power on.
