Extend operating temperature of UP Xtreme Lite
BlackLime21
New Member Posts: 4 ✭
Your website says that the operating temperature range of the “UP Xtreme Edge” is between -20 and +70°C.
I am thinking about using the UP Xtreme Lite Board. Is it possible to extend its operating temperature range to -20°C? Maybe by using the "UP Xtreme Chassis" (https://up-shop.org/up-xtreme-chassis.html)?
Best regards
Is anybody from UP going to answer my question?
the temperature mentioned in the product description is the certified temperature and depends on the components used onboard, no on the chassis.
The UP Xtreme Edge Lite does not have that, while you can still try and use it at extended range, we cannot guarantee for the correct behavior.
Okay, thanks!
