UP2-Pro, No Power Supply or Case
I have a new UP2 Pro, but the power supply and a case are not listed or sold on the UP-Shop site. I found a part number from AAEON 1255X00032 but I don't find any source for this supply. The connector is a threaded type and the supply as a 12V6A model. They list a supply for the UP eXtreme, which has a threaded connector, but it is 19V. The UP Core Plus supply is 12V5A, but the connector pin dimensions appear to be too small.
Can anyone point me to a source for a compatible power supply?
Likewise, there appear to be no case to fit the slightly larger UP2-Pro. I assume that one is in the works?
Welcome!
