Program Arduino pro-mini with UP2
noobie
noobie New Member Posts: 3 ✭
Is it possible to program Arduino pro-mini via UP2? and if so; how?
Can you give some details about how to make the connections etc.
Would I be able to keep using the Arduino IDE?
  • camillus
    camillus AAEON Posts: 188 mod
    edited September 2021
    Hi @noobie ,
    Kindly refer to the pinout page for UP2 here. From the Arduino Pro Mini guide I see that you can connect the Arduino Pro Mini to the UP2 using an FTDI TTL -USB cable and you can install the Arduino IDE and upload the sketches. Try it out and kindly share with us when it works.
    Best regards,
