Enabling More UART interfaces from Up Board
unregistered
New Member Posts: 1 ✭
My application requires 4 UART interfaces from the Up Board. Does the ATOM CPU support any additional UART interfaces? If so is it possible to enable them?
Adding USB-UART conversion would be the last resort.
Best Answer
No you cannot have more than 2 native UART (one via 40pin and one via micro 10pin connector).
If you need more, you would require a USB to UART adapter.
@DCleri slope game said:
No you cannot have more than 2 native UART (one via 40pin and one via micro 10pin connector).If you need more, you would require a UBS to UART adapter.
Oh! okay. that make sense
