can't install drivers
Hi all,
I have a problem installing the drivers. I have windows 10 installed and running but while installing the driver package it gives me an error.
Looking around on the forum I see different people having had the same problem (https://forum.up-community.org/discussion/717/installation-of-win10-64-step-1-drivers-fails)) and being able to solve it by removing the spaces in the 'step 1' folder name.
Unfortunately this doesn't work for me.
I saw someone else having had succes by updating the BIOS, so I gave that a try as well, but I also seem to not be able to boot into UEFI, even though having followed the steps.
Is there someone who can point me in the right direction?
Thanks!!
    if the USB stick has been loaded with the files included in the BIOS zip archive, then you need to change the boot order via BIOS menu or pressing F7 to enter the boot menu and select the USB as first boot.
    Once there, the system will boot into UEFI shell, and you can follow the instructions from here: https://downloads.up-community.org/download/736/
