are gpio pins 5v tolerant ?
cannot find this in the wiki or up2 datasheet.
what is the tolerance on the gpio pins ? can i put 5v on them or max 3.3 volt
regards,
Rob Bothof
Welcome!
  • New Member Posts: 146 ✭✭
    I am pretty sure I have read that they are not 5v tolerant, but could be wrong.
    I would assume it is like the RPI and only 3.3v. Also the other special connector I believe is only 1.8v
  • New Member Posts: 9
    I can't believe how hard it is to find a complete datasheet for Up Squared (and no, you can't call this two pages "user manual" a datasheet)... We have litteraly no informations except the wiki, which seems pretty old. Does anyone know more about pins tolerance ?
    Again it would be great if some one from UP/Emutex answered. But again I do not believe that the pins will handle 5v.
    That is by the Kickstarter for UP squared as well as the 2 sheet document, it mentions using an Intel Max 10 FPGA for the IO pins.
    And if you look at the documents for the Max 10, such as:
    https://www.altera.com/documentation/luo1479889762304.html
    And again I don't know how it is hooked up to the main board (single power, multiple power), but the highest voltage I see is 3.3v.
    With multiple power in, it mentions things like:
    Table 12. Power Supply Sharing Guidelines for Intel® MAX® 10 (Dual Supply) FPGA – Using the ADC Feature and VCCIO[2..8] Pins are Powered Up at 1.2V/1.35V/1.5V/1.8V/2.5V/3.0V/3.3V. Example Requiring 4 Power Regulators
    But again hopefully some one else has more definitive answers.
    I reopen this subject as i could not find anything on this forum/wiki and upsquare documentation and i need to build a custom electronic board.
    For all GPIO:
    What is the Vol_max, Voh_min/max, Vilmax, Vih_min/max?
    What is the max Isink/Isource capabilities by pin and over all pins ?
Welcome!
