Setting Up a Motion Sensor on Up Xtreme with Ubuntu
Hi there, I was recently sponsored with an Up Xtreme for a project I'm working on, and am still learning how to use it.
I would like to set up a motion sensor to use as a stimulus to run a program when activated. However, as I have no experience with this sort of hardware setup/interfacing/programming, I need some help in figuring out how to accomplish this. Most of the guides online are for Raspberry Pi/Arduino, so it would be helpful if someone could guide me in this matter.
My objectives are:
1. Figure out and get all the necessary and compatible hardware components
2. Set them up properly to interface with the Up computer board
3. Access the input/output from the motion sensor so that I can run a program when the sensor detects motion
As I am completely new to this kind of configuration, any help is useful and appreciated.
Sam
Hi @Samberlance ,
Glad to know about your new project.
I think our UP Wiki can be of help here, visit https://github.com/up-board/up-community/wiki/Hardware#up-xtreme for hardware details for UP Xtreme and its setup, along with the pinout details.
If you want some help for setting up your Ubuntu, please also check out the setup instructions for Ubuntu here, https://github.com/up-board/up-community/wiki/Ubuntu
Hope this helps
Regards,
Pratik
