SPI clock speed range
MoA
New Member Posts: 13 ✭
What is the minimum and maximum speed of the SPI?
If the speed is OS dependent, we are using Windows 10.
Mo
@MoA
For SPI clock, the maximum speed is 25 MHz and the minimum acceptable value is 1MHz -
@rogertsai(AAEON) png to ico said:
@MoA
For SPI clock, the maximum speed is 25 MHz and the minimum acceptable value is 1MHzi got it, thank you for the explanation.
