Up core with display 7" no touch
I bought an Up core and a 7 "screen.
I plugged everything in as indicated on the screen manual.
I installed android 6.0 for Up core but I don't have touch.
Can you help me?
@Allwan
Check your cables and connections. Make sure that your Panel and cables are plug in correctly
Touch cable
to USB Wafer connector (UP CORE - CN7)
Plus, may I know your current BIOS version?
yes, the connectors are well positioned.
And the BIOS version is R1.8
@Allwan
Ok, please confirm the below for me
1. Does the touch panel working in BIOS?
2. Are you using the right Android 6.0 for Up core? Android version: 6.0.1 (android-6.0.1_r3) as below link
https://downloads.up-community.org/download/android-6-0-image-for-up-core/ -
- No it doesn't work in the bios
- yes, this is the correct file that I downloaded
Is there a parameter to change in the bios?
I also had this during installation.
and I have this at startup
@Allwan
The touch panel should work in the BIOS, there's no need to configure any parameter or change BIOS settings.
Therefore, you should double-check your cables. If the touch still not working, it's probably due to issues with the broken cable, or touch defective. -
the cables are correctly connected
