Unable to build WIndows IOT core Image
I am following instructions to build a Windows IOT Core flash.ffu file. https://downloads.up-community.org/download/windows-iot-core-bsp-and-guide/
I always get an error on the BuildImage Step
Package is missing from \?\C:\Program Files (x86)\Windows Kits\10\MSPackages\Retail\AMD64\fre\Microsoft.IoTUAP.IoTUAPProductSpecificFM~31bf3856ad364e35~AMD64~~.cab
Even when I do no customization and type the exact commands in the document screenshots, I get the error. (except your example has the BSPName as APLx64 instead of UPAPL in the Add-IotProduct step). I have installed all the versions of the tools from the current https://docs.microsoft.com/en-us/windows-hardware/manufacture/iot/set-up-your-pc-to-customize-iot-core web page.
@jmadeley
could you provide more information from IoTCorePShell as below, ADK version and IOTCORE version should be the same. -
All versions the same except it looks like you have a different version of IoTCoreShell. You have 6.0.200306.820. I have 6.0.200326.1705. I got the current version off of GitHub (https://github.com/ms-iot/iot-adk-addonkit/). Could you give me a link to your IoTCoreShell version so I could test to see if that solves my problem? Any other ideas?
Thank you so much for your help!!! -
@jmadeley
No matter which version of iot-adk-addon kit you are using, I can build succeed in the latest one,based on your error message, do you have modified your TestOEMInput.xml?
I have tried to build from your instructions with no modifications to TestOEMInput.xml
I Download iot_core_build_20200603 and extract to d:\
I make a blank d:\TestWS subdirectory
I run IotCorePShell as administrator
new_ws "D:\TestWS" AAEON x64
importpkg *
copy-item -force -recurse -Path "D:\iot_core_build_20200603\BSP*" -destination "D:\TestWS\Source-x64\BSP\"
copy-item -force -recurse -Path "D:\iot_core_build_20200603\Packages*" -destination "D:\TestWS\Source-x64\Packages\"
Add-IoTProduct
UPS_Test
UPAPL
AAEON
UPS
UPS-APLC2
AAEON
UPS-APL
BuildPkg All
BuildImage UPS_Test TestI have attached a log of the PShell output as well as a screen shot of the error message.
I tried the build on a different computer and did not get the error on the BuildImage command.
Some typos on my procedure above are corrected below:
new-ws "D:\TestWS" AAEON x64
importpkg *
copy-item -force -recurse -Path "D:\iot_core_build_20200603\BSP" -destination "D:\TestWS\Source-x64"
copy-item -force -recurse -Path "D:\iot_core_build_20200603\Packages" -destination "D:\TestWS\Source-x64"
Add-IoTProduct
UPS_Test
UPAPL
AAEON
UPS
UPS-APLC2
AAEON
UPS-APL
BuildPkg All
BuildImage UPS_Test Test -
@jmadeley
weird, I follow your steps and still build succeed. you can check the build logs as attached looks I didn't required the package Microsoft.IoTUAP.IoTUAPProductSpecificFM~31bf3856ad364e35~AMD64~~.cab
