UART1 pin configuration
Regarding UART1 on the 100-pin header on the Up Core (i.e., pins 12, 14, 16, and 18), does anything need to be set in the BIOS to configure these pins to function as a UART?
Looking at the two commercial carrier boards available for the Up Core, it seems that these pins are not used on CRST01 and are connected to an FPGA on CRST02...
